Hello, I am trying to destroy all current '}CellSecurity_' and '}ElementSecurity_' Cubes via TI ( with dimension '}Cubes' as data souce and SUBSET = 'ALL') , but I found a strange behavior that I have to run TI 3,4 time to delete every }CellSecurity_' and '}ElementSecurity_' Cube , its deleting some cubes in every run instead of at once
MetaData Tab:
If( Subst(vCube,1,14) @= '}CellSecurity_' % Subst(vCube,1,17) @= '}ElementSecurity_');
CubeDestroy(vCube);
Endif;
Does anyone knows reason for this, or the better approach would be removing these .cub files from data directory rather then destroying via TI, thanks
Destroying '}CellSecurity_' and '}ElementSecurity_' Cubes via TI
Re: Destroying '}CellSecurity_' and '}ElementSecurity_' Cubes via TI
Try instead having no datasource and looping the dimension backwards:
iCount=DimSiz(cDim);
While(iCount > 0);
sCubeName= DimNM(cDim, iCount);
If....
Endif...
iCount = iCount - 1;
End;
- Version: 10.2
It worked ..!., thanks Declan
