Planning Analytics Perspectives Issue
CathyBoots
OLAP Product: Tm1
Excel Version: Prof Plus 2013
Post by CathyBoots » Mon Dec 19, 2016 8:11 am
Hi everyone
I've installed the new Planning Analytics on Prem and now I'm having an issue starting Perspectives.
Everytime I try to start it, I get the message
Missing Library: C:\Program Files\ibm\cognos\tm1_64\bin\gsk8ssl.dll
C:\Program Files\ibm\cognos\tm1_64\bin\gsk8km.dll
Has anyone encounter this before or know how to resolve it please?
The files do exist within the directory specified.
I'm using Excel 2013 v15.0.4885.1001 (32bit)
Thank you
Version: 9.5.2 64 bit moving to 10.2.2
Re: Planning Analytics Perspectives Issue
Post by Alan Kirk » Mon Dec 19, 2016 8:19 am
CathyBoots wrote:Hi everyone
I haven't installed it yet so I haven't seen the install paths but from that path it looks like you may be using the 64 bit add-in that came out for 64 bit Excel some time in 10.2.2. If you have 32 bit Excel you still need to use the 32 bit add-in. Is there another bin folder (one on a path that does not have _64 in it) containing a tm1p.xla add-in? If so, try that one instead.
CathyBoots
OLAP Product: Tm1
Post by CathyBoots » Mon Dec 19, 2016 8:39 am
I tried both the one that sits in \bin and the one in \bin_64, but they give the same message.
Post by tomok » Mon Dec 19, 2016 2:01 pm
The key question is which version of Perspectives did you install, the 32 or 64-bit? If you installed the 64-bit version and you have 32-bit Excel then it isn't going to work. Uninstall the client and install the 32-bit version.
CathyBoots
OLAP Product: Tm1
Post by CathyBoots » Tue Dec 20, 2016 7:53 am
I did that, but still no luck.
WouterM
OLAP Product: IBM Cognos TM1
Post by WouterM » Wed Dec 21, 2016 10:52 am
Same issue here. Running 32-bit client on 32-bit Excel on Windows 7 64b. The files gsk8ssl.dll and gsk8km.dll do exist.
Update (without success):
* Fiddling with the windows PATH didn't change anything.
* Uninstall/re-install didn't change anything (no errors in install log)
* gsk8ver runs and lists gsk8ssl.dll and gsk8km.dll
!TM1Rules
OLAP Product: TM1\Cognos Express
Version: All
Excel Version: 2013 + 2016
Post by !TM1Rules » Tue Jan 10, 2017 4:53 am
Anyone got any updates on this issue? I don't think it is a 32-bit vs 64-bit issue, as Perspectives was working until after I installed PAX. Once PAX installed, even disabling the new add-ins didn't fix the issue. Does anyone know a method of forcing Excel to open without third party add-ins (other than safe mode)?
dumbom
Version: CX 10.1 and TM1 10.0
Excel Version: 2007 and 2010
Post by dumbom » Fri Nov 03, 2017 9:40 am
We have had the same issue. We resolved this by uninstalling the package connector (then restarting the machine)
there is a known issue with perspectives 2.0 installed alongside package connector
CathyBoots
OLAP Product: Tm1
Post by CathyBoots » Fri Nov 03, 2017 10:38 am
We did the package uninstall and that worked for getting perspectives to work. Thank you guys for your help :)
There is a known issue with PAX and perspectives though, you can't use perspectives if PAX is installed. I'd uninstall PAX if you are wanting to use Perspectives.
Version: 10.2.2., PAW
Post by Steve Rowe » Fri Nov 03, 2017 1:06 pm
Pretty sure that they both can't be loaded in Excel at once but you don't have to uninstall PAx
It works for a while but for example if you try and slice from a perspectives cube viewer with PAx loaded but not connected then the slice fails.
From our experience perspectives works fine if you don't have PAx loaded in Excel but you don't have to uninstall it. You can remove PAx from Excel through the add-ins menu.
This means that you can switch between clients as required.
Mumsy
Version: 10.2.2 FP4
Post by Mumsy » Wed Jul 11, 2018 6:44 am
If you are using MS Excel 32-bit so you may try to copy all gsk8*.dll files from the Planning Analytics install \bin directory to the Package Connector \bin directory.
