Blank Rollup for Non-Admin user
Posted: Sun Nov 27, 2016 9:10 am
Hello friends,
For a Non-Admin user, (TM1 Perspectives, 10.2.0 on Windows Server 2008 R2 Enterprise OS), the user-defined rollup values are blank for the Dimension used in Security / Approval Hierarchy of a TM1 Application, though individual element values are populated correctly. Also, for all other normal / non-security dimensions, the rollup values are populated correctly.
For Admin-user the rollup values are populated correctly for all Dimensions, including Security Dimension.
Note: This happens only for a TM1 Server that is using TM1 Application. However, for other normal TM1 Servers, rollup values are populated correctly for Non-Admin users, on the Security Dimension. As TM1 Application Security is managed through Contributor Web, are there any specific setups / parameters that need to be taken care, or is it a known bug in 10.2.0.
Appreciate any help / suggestions.
