SSL Cert uptade and pmpsvc settings
Posted: Fri Nov 25, 2016 3:46 pm
by Elessar
Helo all,
Please keep in mind that after you had reinstalled the pmpsvc service, the pmpsvc tuning in "tomcat6w.exe //ES//pmpsvc" will become default. The "Maximum memory pool", which can be set in Cognos Configuration, will become default too. CogConfig will still show the old value (of cource it will: it does not know that somebody reinstalled pmpsvc ;) )
So, if you didn't change anything in "tomcat6w.exe //ES//pmpsvc", just save the Cognos Configuration.
If you did, you should remember and repeat it.
