This is of course a question for IBM, but I’ve asked them, and no one seems to be able to give me a definitive answer. ...or I have just asked the wrong person.
This is what I have done:
I have created a VBA project that burst reports, i.e. generate different versions of a report for a combination of e.g. period, company, product, etc. The different reports are then saved without TM1 formulas, and finally emailed to a large user group. Some of the recipients are TM1 users, but some are not. Will this violate the IBM licensing, i.e. distribute ‘TM1 reports’ to non TM1 users?
What if I do this manually using current functionality in the product, e.g. export a snapshot and then email the report to a non TM1 user? Will this also violate the license, or is it the burst functionality that is the problem (if it is?).
Licensing
- Version: TM1 11 and up
Re: Licensing
You're using one licence to create some Excel reports and then sending them out. There's no need for the recipients to use a TM1 licence. I don't see a licence issue here - why do you think there is one?
Paul
Re: Licensing
Agreed. IBM does not own the data you have in your TM1 models. If you are simply sending out Excel workooks that were sourced from Perspectves does not mean the ultimate recipient needs a TM1 license. At this point it's just an Excel workbook that no longer needs the TM1 add-in to function.Paul Segal wrote:You're using one licence to create some Excel reports and then sending them out. There's no need for the recipients to use a TM1 licence. I don't see a licence issue here - why do you think there is one?
- Excel Version: 2013
Re: Licensing
Thanks guys! Valuable input as always.
