We are currently running TM1 10.2.2 FP3 on Windows 2008 servers, and I am researching upgrade to FP6.
Is there a single document anywhere that lists known problems or issues in version FP6?
TM1 10.2.2 FP6 - known problems list?
Re: TM1 10.2.2 FP6 - known problems list?
Of course IBM is not going to provide you with a document "the official list of problems with our software".
I also don't see why anyone here should go out of their way to hand feed you a list of issues by investing their own time and effort compiling a list (unless they have already undertaken the effort for their own purposes and are happy to share). If you have a look around here it should not be too hard to spot a few largish issues.
- Version: 9.5.1
- Excel Version: 2003 2007
For instance the threadlotsaram wrote:If you have a look around here it should not be too hard to spot a few largish issues.
http://www.tm1forum.com/viewtopic.php?f=3&t=12634
TM1 10.2.2 FP6
on how to use the TI fct DisableMTQViewConstruct() to force a pre-FP6 behaviour, see the IBM Technote 7048366
http://www-01.ibm.com/support/docview.w ... wg27048366
TM1 10.2.2 Fix Pack 6 - Using multi-threaded query to execute a view as a TurboIntegrator data source
- Version: 9.5.2 FP2
- Excel Version: Excel 2007
Ok thank you!moby91 wrote:For instance the threadlotsaram wrote:If you have a look around here it should not be too hard to spot a few largish issues.
TM1 10.2.2 FP6
