Wait:IXCur on user login during TI data load
4rtem
Post by 4rtem »
I have a TI data load process that causes users to wait during integrated login. This situation is reflected in TM1Top in the following way:
USername: ???
State: Wait:IXCur (UserName) - (Client)
Function: SystemServerConnectIntegrate
Obj Lock Status: Client
This TI process does not create subsets, change view, does not touch control cubes and dimensions directly. It just operates with dimension elements and cube data. Can CubeSetLogChanges(vCube,0) drive such behavior?
We use 64x TM1 10.1.
Thanks.
“The way to get started is to quit talking and begin doing.” - Walt Disney
pandinus
Re: Wait:IXCur on user login during TI data load
Post by pandinus »
4rtem wrote:Can CubeSetLogChanges(vCube,0) drive such behavior?
Yes.
And also metadata updates may be blocking.
BrianL
Version: 9.5.2 10.1 10.2 PA2
Post by BrianL »
It looks like the the TI process is touching the client objects. Are you doing anything with the TM1User() function or the }Clients dimension in the TI?
4rtem
Post by 4rtem »
No operations with TM1USer() and }Clients dimension and any of control cubes/dimensions.
Statistic cubes are active on the server, maybe it is the source of locks...
I will turn it off tomorrow and check if it helps.
dhims
Version: 951 952 101 10101
Excel Version: 2003 2007 2010
Post by dhims »
Hi 4rtem,
Just thought of checking with you how you resolved this issue. I am facing exactly the same issue on (10.2.2 FP5). I disabled the command that plays on cube logging. There is no commands that play on control objects. But, I am still getting the same locking contention.
Any help will be highly appreciated.
Dhims
4rtem
Post by 4rtem »
Do not use CubeSetLogChanges.
If you want to turn on/off logging in the cube set the LOGGING property on the
}CubeProperties cube directly.
That worked for me.
ambrus
OLAP Product: Manny's TM1
Post by ambrus »
That is only the old wisdom, isn't it? AFAIK this was sorted somewhere around 10.2.2 FP4+
Rest API addict, creator of http://cubeac.com || Blog http://cubeac.com/blog/
