With which version of Java is TM1 10.2 web developed?
Posted: Wed Jun 08, 2016 9:48 am
by Learn_TM1
IBM document shows that TM1 10.2 web is developed by Java. But it doesn't say which version of Java? Could you please tell me about it? Thanks.
Learn_TM1
Re: With which version of Java is TM1 10.2 web developed?
Posted: Wed Jun 08, 2016 11:49 am
by jwilkins
It looks like they use Java 1.7. Naturally, that's IBM Java 1.7.
- java_version.png (34.09 KiB) Viewed 6893 times
Posted: Wed Jun 08, 2016 1:16 pm
by Learn_TM1
Hi jwilkins,
Thanks for your reply. Unfortunately I didn't finde /jre/ folder in my Cognos TM1 installation. I only find the folder as:
C:\Program Files\ibm\cognos\tm1_64
And I can't run "java -version" command.
Is there some official IBM document to declare what Java version is used to develop TM1 products?
Posted: Wed Jun 08, 2016 2:15 pm
by jwilkins
I don't know of any official documentation that explicitly says the Java version. However this article may help you locate the jre folder.
https://www.ibm.com/support/knowledgece ... view=embed
You can then run java.exe in IBM_7.0\bin with the -version flag to get the same printout as my screen shot.
Your path would probably be
C:\Program Files\ibm\cognos\tm1_64\bin\jre\IBM_7.0\bin\java.exe
Posted: Wed Jun 08, 2016 3:40 pm
by Learn_TM1
Hi jwilkins,
Thanks for your tips. I found the folder on the server, where Cognos TM1 installed. And I got the Java Version, which is same as yours.
Learn_TM1
Posted: Thu Apr 05, 2018 10:39 am
by Sophie Kay
Interesting, I've just tried out to test it the same way you've done, me neither didn't find JRE folder, but in my case running version prompt was successful. That's the very thing I can't understand with Java at all: everything works fine by the book, but when you actually trying to do that, it appears to be way more complicated as it supposed to be for another person for sure. I'm new-new to all this stuff, so I'm getting over this with these java tutorials
https://explainjava.com/ because everything here is explained from several prospectives and at least one of them should work in any cases. But nevertheless, now I've determined that it's wrong time for me to get it started with TM1
Posted: Thu Apr 05, 2018 12:42 pm
by tomok
Sophie Kay wrote: ↑Thu Apr 05, 2018 10:39 am
Why do you feel it necessary to learn Java to be able to develop and/or use TM1? You're talking about code that happens behind the scenes in TM1. You should never change the Java version that comes with TM1 nor change anything in the Java code. I have been developing in TM1 for years and I don't know squat about Java and I'm doing fine.
Posted: Sat Apr 07, 2018 8:26 pm
by moby91
You may consider to apply the Interim Fix 24 for TM1 10.2.0.2 or the Interim Fix 12 for TM1 10.2.2.7 to address a vulnerability in the IBM Runtime Environment Java Version 7, see the latest security bulletin
1)
http://www-01.ibm.com/support/docview.w ... wg22015269
Security Bulletin: A vulnerability in IBM Java Runtime affects IBM Cognos TM1
Security Bulletin
Summary
There is a vulnerability in IBM Runtime Environment Java Version 7 used by IBM Cognos TM1.
This issue was disclosed as part of the IBM Java SDK updates in October 2017.
Vulnerability Details
Affected Products and Versions
IBM Cognos TM1 10.2
IBM Cognos TM1 10.2.2
Remediation/Fixes
The recommended solution is to apply the fix for versions listed as soon as practical.
Cognos TM1 10.2.0.2 Interim Fix 24
Link:
http://www.ibm.com/support/docview.wss?uid=swg24044711
Cognos TM1 10.2.2.7 Interim Fix 12
Link:
http://www.ibm.com/support/docview.wss?uid=swg24044712
2)
http://www-01.ibm.com/support/docview.w ... wg24044712
Downloadable files
Abstract
IBM Cognos TM1 10.2.2.7 Interim Fix 12 (10.2.2.7 Interim Fix 12) provides important corrections for Cognos TM1 10.2.2.0.
Download Description
This IF provides important product corrections to Cognos TM1 10.2.2.0, and should be applied to all installations at your earliest convenience. It includes all previous fix packs for Cognos TM1 10.2.2.
