TM1 'Set Dimension Order' Not Working
wigglyrat
Version: 10_2_2
Post by wigglyrat » Fri Feb 19, 2016 11:03 am
Hi:
I am trying to set a dimension order manually however after rearranging the dimensions in dimension editor, selecting 'set dimension order' and then 'Dimension' 'Save' it will not preserve the order.
Each time I go in to look, the order of the elements reverts back to the original order before the reordering.
I am trying this in Perspectives, but have also tried in Performance Modeler using 'move up' and 'move down' but have the same result.
Has anyone else experienced this?
Many thanks,
AmbPin
Version: 9.5.2
Excel Version: 2007-10
Re: TM1 'Set Dimension Order' Not Working
Post by AmbPin » Fri Feb 19, 2016 11:49 am
I think the order that you are seeing is the order in which elements were added to the dimension (The index) and therefore this will not generally be affected by you moving them around in the editor.
wigglyrat
Version: 10_2_2
Post by wigglyrat » Fri Feb 19, 2016 12:06 pm
Yes, I think so.
Is there no way to change this then?
It is for a time hierarchy - so my users are not happy to see July before June.
Many thanks for your assistance.
Post by tomok » Fri Feb 19, 2016 12:16 pm
You can put the elements in any order you want if you do it through an XDI workbook.
wigglyrat
Version: 10_2_2
Post by wigglyrat » Fri Feb 19, 2016 12:42 pm
Many thanks for this.
I see that you can create dimensions using xdi/dimension worksheets, but can you create an xdi from an existing dimension if it was not originally built with one?
Kindest,
Version: TM1 10.2.2
Post by jim wood » Fri Feb 19, 2016 12:52 pm
Yes you can. I would read through how to create a dimension using an XDI. Keep in mind your local server setting etc. Especially if you want multiple people editing the dimension. Another option is to recreate it using a CSV and TI. If you set the order in the TI or even within your CSV you should be good. Hopefully this will then be a one off exercise.
Application Consulting Group (ACG) TM1 Consulting
OS: Windows 10 64-bit. TM1 Version: 10.2.2
AmbPin
Version: 9.5.2
Post by AmbPin » Fri Feb 19, 2016 1:19 pm
There are various sorting options available to you via MDX also if you wanted to create some dynamic subsets.
Post by tomok » Fri Feb 19, 2016 1:33 pm
wigglyrat wrote:Many thanks for this.
Kindest,
Right click on dimension and choose Export Dimension. This will create a CSV version of what the XDI would look like to create that exact same dimension. Open the file in Excel with Perspectives loaded, move the elements around to get the desired order, then save as an Excel workbook with the name "YourDimensionName,xdi". Don't forget the quotes around the name or otherwise you'll get a file name of YourDimensionName.xdi.xlsx. You can save the dimension on the server by choosing TM1, Developer, DImension Save.
FWIW, any time I have a smallish dimension that has to be in a specific order, that is not alpha sortable, then I use an XDI to ensure I get the dimension ordered exactly as I want it. As others have stated, you CAN accomplish this through TI but it's not nearly as easy if you have an already existing dimension.
wigglyrat
Version: 10_2_2
Post by wigglyrat » Fri Feb 19, 2016 3:16 pm
All very helpful, thank you for your replies.
paulsimon
Version: PA 2.0.5
Post by paulsimon » Sun Feb 21, 2016 12:25 am
I would also check the }DimensionProperties cube for that dimension to see if any Sort Order has been stored there.
babytiger
Post by babytiger » Fri Feb 26, 2016 6:51 am
Is there a default subset created for this dimension? Is it possible that you were looking at the default subset order instead of the indexed order?
MK
Xavier 13
Excel Version: Excel 2010
Post by Xavier 13 » Thu Oct 04, 2018 10:21 am
I found this topic for the same issue, the button "Set Dimension Order" seams not to be working. It does, but you need to save changes to the structure of the dimension before.
Arrange your elements.
Press "Set Dimension Order" button
Save your changes
Then only re-open the dim editor and your elements indexes will be correct.
Version: PAL 2.0.6
Excel Version: 2016 - Office 365
Post by Wim Gielis » Thu Oct 04, 2018 10:26 am
Save your changes
Thanks for posting. But isn't it normal behaviour that you save (or cancel) the changes you make - in this case dimension changes ?
If you don't save, TM1 will ask you anyway.
http://www.wimgielis.com ==> 107 TM1 articles and a lot of custom code
Newest blog article: Turbo Integrator: report on progress
Xavier 13
Post by Xavier 13 » Mon Oct 15, 2018 12:29 pm
Well it's stupid but I was keeping the subsets editor open and was expecting to see the index changing in the details panel right away after I pressed the button.
