Hello team,
Did anyone of you used TM1 cubes as data source Microfoft BI tools, such as PowerBI?
If you are interested in having this feature in MS BI, please vote here:
https://support.powerbi.com/forums/2652 ... ata-source
Cognos TM1 as data source in Microsft BI
- mce
- Version: Planning Analytics Local 2.0.x
- Excel Version: 2013 2016
Re: Cognos TM1 as data source in Microsft BI
I just saw the post in http://www.tm1forum.com/viewtopic.php?f ... it=powerbi
It looks third party Gateway product helps with this.
- OLAP Product: TM1 9x, BPC, Hyperion, HANA
- Version: TM1 10
- Excel Version: Excel 2003 - 2010
Power Query natively supports Odata V4 Payload which is the format you will get if you enable REST API on TM1 10.2.2 hence I would rather go down that path.
https://support.office.com/en-us/articl ... _176341939
I have not tested that yet but looks promising from a visual perspective .
- Version: 2.x
- Excel Version: 36x
Unfortunately it 's not a straight forward task of using OData connection from PowerBI with TM1 Rest. Give it a test and you will know the issues.
Hi, if you are looking to report from TM1 within PowerBI, you might be interested in the connector we have built to do this. If you'd like to discuss this further please email me at Dave.kerby@simpson-associates.co.uk
Dave
Dave
- stephen waters
- Version: 10_2_2
- Excel Version: Excel 2010
CarpeDatum have a connector, TM1Connect, which links TM1 to Power BI (pLus Tableau and Qlik I think).
We are currently working with one of our clients on the Power BI\TM1 connection and initial tests results are good.
I think a couple of other partners have something similar as well.
