Hi Experts,
I have a measure C = A - B (A is static during the day) B is where Users enter their numbers
C is used ONLY to capture where the user has changes during the day. ( I don't need C to be fed)
I created a TI process that reads C to update A (when needed).
The TI does not EXTRACT non fed leaf level cells. Is that normal?
In my extract, I obviously have:
ViewextractskipZeroesSet to 1 (to exclude the zeroes).
Thank you
TI process does not pick non fed leaf level cells
- Version: 2.0
- Excel Version: EXCEL 2013
Micheline
Micheline
Re: TI process does not pick non fed leaf level cells
If you want a TI to read rule calculated cells from the data source you would need to set ViewExtractSkipRuleValuesSet to 0.
If you suppress zeroes then yes, unfed cells will be skipped.
Suggest you do C = A - B as a subtraction hierarchy which will not need feeding - although it would not then be N level.
- Version: 2.0
Thank you so much both Declan and David. Yes Declan I had the rules to be picked up, but it was not doing it.
But I will definitely take David's idea of a hierarchy.
Thank you so much
Thank you so much
Micheline
Micheline
