MDX in ActiveForm with "INSTR" does not work
Mark2007
Excel Version: Excel 2010
Post by Mark2007 » Mon Apr 27, 2015 7:12 am
Hi there,
I created a MDX-Statement, that works in the Subset editor and gives results, but does not work in an activeForm.
MDX-Statement: {Filter( { TM1SUBSETALL( [DimName])}, INSTR([DimName].[AliasName], "EKMS_33446") <> 0)}
Other MDX-Statements work in the ActiveForm, such as:
{TM1FilterByPattern({TM1SubsetAll([DimName])}, "EKMS_33446*")}
My aim is to create a MDX, that gives me a List of Elements where the Alias (!) are partly the same, e.g.
EKMS_33446_Name1
UK_12345_Name1
NE_234123_Name1
and I would like to get a MDX that looks for "Name1" in the Alias and lists all of the three.
I'm working with TM1 10.1.
Excel 2010
Any Ideas?
Mark
rmackenzie
Re: MDX in ActiveForm with "INSTR" does not work
Post by rmackenzie » Mon Apr 27, 2015 8:04 am
Mark2007 wrote:I created a MDX-Statement, that works in the Subset editor and gives results, but does not work in an activeForm.
Does it only work in the subset editor when you have the alias actually turned on? If it doesn't work in the subset editor when aliases are off then at least you know it's consistent with the Active Form.
Robin Mackenzie
tm1_bloke
Post by tm1_bloke » Mon Apr 27, 2015 8:14 am
I have similar experiences that INSTR doesn't work in Excel Active Forms BUT when the same active form is uploaded in TM1 Web, it works there without any issues.
Mark2007
Post by Mark2007 » Mon Apr 27, 2015 2:09 pm
In Subseteditor, the MDX works, even if the Alias is not activated.
Mark2007
Post by Mark2007 » Mon Apr 27, 2015 2:10 pm
tm1_bloke wrote:I have similar experiences that INSTR doesn't work in Excel Active Forms BUT when the same active form is uploaded in TM1 Web, it works there without any issues.
Hi there, you're right, it works in web! Thanks!
Mark
summerbrewgal
Version: 9.4
Post by summerbrewgal » Tue May 17, 2016 8:31 pm
In case anyone needs it to work in Perpsectives too, if you set the 4th optional parameter of InStr to 1 (text compare) that the function will work in both Perspectives and the web.
Change this:
to this:
MDX-Statement: {Filter( { TM1SUBSETALL( [DimName])}, INSTR([DimName].[AliasName], "EKMS_33446",1) <> 0)}
OLAP Product: TM1, CX
Version: TM1 10.2.2 PA 2.0x
Excel Version: 2010 2013 365
Post by lotsaram » Thu May 19, 2016 4:38 pm
summerbrewgal wrote:In case anyone needs it to work in Perpsectives too, if you set the 4th optional parameter of InStr to 1 (text compare) that the function will work in both Perspectives and the web.
Change this:
to this:
Thanks for the pointer. Hopefully this will help others. I recently came across this very issue found the same workaround, albeit not before I had raised a PMR. I can't help but suspect that the timing of your post is more than coincidence.
cdredmond
Version: SpreadsheetConnector4.0-10.2.2
Excel Version: v3 - 2013
Post by cdredmond » Tue Aug 08, 2017 7:05 pm
Thank you all for this great discussion on this unlisted, but unofficially available INSTR MDX function in TM1!
A special thanks to SummerBrewGal for her post about using the optional fourth "language compatibility" parameter. Your post sent me down the path to explore this option which ultimately led to my discovery! :-)
After some extensive testing, here is what I have found while working on TM1 v10.2.2 FP7 with IntegratedSecurityMode=5.
INSTR works pretty much as expected in the Perspectives Subset Editor. Beyond that, its a crap shoot with each tool.
Specifically, in TI the sub-string to match (third parameter) is limited to four characters. Beyond that, it returns an empty set.
To get around this problem, you must use the "optional" parameters. Both "optional" parameters MUST be used.
If you use the fourth parameter without the first parameter, an error is generated.
Here is example MDX code I used to get a pattern match out of the }TM1_DefaultDisplayValue alias in the }Groups dimension:
{ FILTER( { TM1SUBSETALL( [}Groups] ) }, INSTR( 1,[}ElementAttributes_}Groups].([}ElementAttributes_}Groups].[}TM1_DefaultDisplayValue]), ".NorthAmerica.",1 ) > 0 ) }
This code returns a set of elements with the sub-string ".NorthAmerica." in the Group name which came from MS AD similar to the list below.
ActiveDirectory\Application.CognosTM1.NorthAmerica.AdvUser.Contributor
ActiveDirectory\Application.CognosTM1.NorthAmerica.User.Contributor
ActiveDirectory\Application.CognosTM1.NorthAmerica.User.Explorer
Christopher Redmond
Senior TM1 Consultant
http://www.bpmnw.com
Office: (503) 747-2614
iansdigby
Version: 9 + 10
Excel Version: 2007 Professional
Post by iansdigby » Tue Jul 10, 2018 3:35 pm
...and you must include both the first and the fourth '1' parameters to get Instr to work in Perspectives too. e.g.
{FILTER([Employee].MEMBERS,Instr(1,[Employee].[EmployeeID_Name],"Jones",1)<>0)}
That is at least true of Plan An 2.0
