I have an issue with a migration between 10.1 and 10.2.2.
The situation is this:
In my 10.1 there are some ad hoc report formed by a high number of active forms (some of them arrive to 13). In 10.1 the load of these sheets is slow but it doesn't give any issue (not even in a situation of around 100 users connected and working).
In the passage to 10.2, it seems that opening just one of these forms crashes the application server or locks it not permitting anyone to log in.
I tried as a test to remove some parts from one of these reports (mainly formatting styles and some calculated attribute in the header) and I can get it to load but opening a second form (also a basic one) still bring me to the same situation of lock/crash.
I tried to play a bit with the buffer parameters on the tm1web_config.xml but I couldn't get any sensible improvement.
Any ideas?
