TM1 If Statement Help
CapAmerica
Post by CapAmerica »
Now as most of you already know, i'm still new to TM1 and while reading some of these postings I am unable to find out why my if statement is not working. Can any of you tell me what I am doing wrong?
IF ( SCENARIO_SHORT = 'Act@Act'); SCENARIO_SHORT = '1'; ElseIf(SCENARIO_SHORT <> 'Act@Act'); SCENARIO_SHORT = '0'; ENDIF;
Re: TM1 If Statement Help
When comparing against a string literal, you need to use the @ symbol in front of your operator i.e.
IF ( SCENARIO_SHORT @= 'Act@Act'); SCENARIO_SHORT = '1'; ElseIf(SCENARIO_SHORT @<> 'Act@Act'); SCENARIO_SHORT = '0'; ENDIF;
BR, George.
When doing a string comparison you need yo use "@=" or "@<>".
The elseif would also be redundant in this case; you are checking for everything that isn't covered by the original IF so just use else.
AliUgur
Version: TM1 10.2.2
Excel Version: Excel 2013
Post by AliUgur »
ı think your code should be like this;
ELSE;
ENDIF;
Also whike you are using '@=' operator for matching the string value , you can not use ' @<>' this operator.. ' @<>' this is just for number as ı know.. The code which ı wrote at the top should be working ..
Good Luck
AliUgur wrote: Also whike you are using '@=' operator for matching the string value , you can not use ' @<>' this operator.. ' @<>' this is just for number as ı know.. The code which ı wrote at the top should be working ..
Good Luck
Yes you can "@<>" is for string "<>" is for numbers. "@<>" would fail on a number comparison.
CapAmerica
AliUgur, declanr, and gtonkin thank you guys my IF statement is working like a charm! Thanks again, as I forgot that I needed the @.
