Using TM1 version 10.1.1. We have an issue where the security has been locked down for an element attribute containing sensitive data ie birth date.
The user cannot see or slice out the data from the element attribute cube, however when the user is viewing the data through the Subset Editor with "Properties Window" box ticked
the user can see the value. I have tried formatting the value on the element attribute with no luck in the hope that it would at least mask the value.
Is this a common thing? / bug ? Or is there something I am missing? Out of interest and as an alternative is it possible to turn off properties window for a dimension?
Zark
Security Issue. User can view data in "Properties Window"
- Version: 9.4
- Excel Version: 11
Re: Security Issue. User can view data in "Properties Window
I am assuming you still want the user to access the element? One possible solution is to store the attribute in a separate cube and utilise the tm1user() function in a rule to populate dynamically.
- OLAP Product: TM1 and EV
- Version: 9.1 SP3
- Excel Version: Excel 2010
Thanks Dan, your solution worked perfectly. Can you or anyone else shed some light on why this is? It seems to be inconsistent in terms of how TM1 security is dealt with.
I would expect that if you apply security on the attribute element that this element should be hidden when viewed in the subset editor. It appears as though the subset
editor ignores this completely and allow you to see values you should not be able to see when "Properties Window" is ticked. Its as though its acting as admin.
Can anyone confirm that this is expected behaviour?
Bug vs. "feature"/expected behaviour is a tough one here. I would argue as I expect that you would that this is a bug as the properties window should respect the element security settings of the ElementAttributes cube. But the fact is that is doesn't and never has and has always been like this for many years. So the chance that this bug might be fixed in the current Perspectives/Architect client is effectively 0% I would guess.7Zark7 wrote:Thanks Dan, your solution worked perfectly. Can you or anyone else shed some light on why this is? It seems to be inconsistent in terms of how TM1 security is dealt with.
- Version: 9.1 SP3
Thanks for the confirmation of this undocumented "Feature" Lotsaram. )
Did you try cell security on the }ElementAttributes cube data as opposed to element security on the attribute itself?
Robin Mackenzie
- Version: 9.1 SP3
Hi Rob,
I can confirm that cell security does not work for the }ElementAttributes cube.
Cell security was tested and security set to 'None' and values still appeared for the attribute in question.
Zark
Zark
