Does SubsetMDXSet Work?
image2x
OLAP Product: TM1, PAX, PAW, SPSS
Version: 2.0.916.10 on RHEL
Post by image2x »
I'm testing TM1's 10.2.2 FP1 undocumented SubsetMDXSet function ( see http://www-01.ibm.com/support/docview.w ... wg27042401 ) and thus far cannot get it to function as documented:
### total_lvl_0_w_alias
vDim = 'Legal_Entity';
vMdx = '{[legal_entity].[Total Company],TM1SORT( {TM1FILTERBYLEVEL( {TM1DRILLDOWNMEMBER( {[legal_entity].[Total Company]}, ALL, RECURSIVE )}, 0)}, ASC)}';
vSubset = 'total_lvl_0_w_alias';
SubsetCreatebyMDX ( vSubset, vMdx );
SubsetMDXSet ( vDim, vSubset );
The documentation is unclear on if the subset needs to already exist which is why I have the SubsetCreateByMDX statement included. Results:
* If dynanmic subset already exists, there is no conversion to a static subset.
* If run as 'SubsetMDXSet ( vDim, vSubset, vMdx)', no subset is created.
-- John
Re: Does SubsetMDXSet Work?
From your code snippet it doesn't look like you're using SubsetMDXSet correctly as it's missing the 3rd argument of the MDX to pass in to reset the subset!
image2x
Post by image2x »
Yes, thank you lotsa... that was it. I'm used to Unix commands where optional parameters mean optional!
buncikp
OLAP Product: TM1+Cognos Express
Version: 9.5.2+10.1+10.2
Excel Version: 2007+2010
Post by buncikp »
image2x wrote:I'm testing TM1's 10.2.2 FP1 undocumented SubsetMDXSet function ( see http://www-01.ibm.com/support/docview.w ... wg27042401 ) and thus far cannot get it to function as documented:
-- John
If I got it correctly the way to use the function on subset from scratch (just make sure to have SubsetName not coliding with existing one):
# Create empty subset
SubsetCreate(<DimName>, <SubsetName>);
# Attach MDX and make it dynamic
SubsetMDXSet(<DimName>, <SubsetName>, <MDXQuery>);
# Detach MDX query and make it static
SubsetMDXSet(<DimName>, <SubsetName>, '');
