Memory Error / Server Crash in 9.1 SP2 U3
rossi
Post by rossi »
I got the following Memory Error in 9.1 SP2 U3 Build : 9.1.20300.185
4316 WARN 2008-06-18 05:34:50,031 TM1.Server.Memory al_Alloc() outOfMemory Exception <<< MEMORY_TEMP_POOL_EXCEEDED >>> - threadID "4316" - apifunc# "131" - pool# "0" - poolsize "81060608.000000"
Has anyone seen this before please?
thank you
Paolo
jim wood
Version: PA 2.0.7
Re: Memory Error / Server Crash in 9.1 SP2 U3
Post by jim wood »
Check your setting for MaximumViewSize in your config file. If you are on windows 32 bit the default is 100MB. You may want to set it to something higher. See if this works,
Shop at Amazon
rossi
Post by rossi »
64 bit server and it has 64GB of RAM
jim wood
Version: PA 2.0.7
Post by jim wood »
I would still check your setting in your cfg file. If you have no setting try putting it up to 1GB (1024).
Shop at Amazon
