MDX Issue
Analytics123
OLAP Product: Tm1
Version: 9.5
MDX Issue
Post by Analytics123 » Wed Feb 14, 2018 6:01 pm
Hi ,
I am using the below mdx on an insert subset to test the results .
{Filter({TM1FILTERBYLEVEL({DESCENDANTS([Customers SoldTo Only].[Region - 001]) }, 0)},([AR History].[AR Measures].[Recent Activity],[AR History].[Months].[Feb 2018])=0)}
I want to check the value of Recent activity for all the n level customer under Region 001 for Feb 2018 .
But I am getting an error like
Syntax error at or near '[AR History].[Months].[Feb 2018])=0)}', character position 132 .
Can the filter condition be on 2 dimension values , ([AR History].[AR Measures].[Recent Activity],[AR History].[Months].[Feb 2018])=0)
Should I use something like tuple in cognos .
Any help is appreciated . If that works I will alos need to know count the accounts .
Analytics123
OLAP Product: Tm1
Version: 9.5
Re: MDX Issue
Post by Analytics123 » Wed Feb 14, 2018 6:15 pm
Also I tried this with just one dimension on filter condition .
{Count(Filter({TM1FILTERBYLEVEL({DESCENDANTS([Customers SoldTo Only].[Region - 001 - CROSSROADS - CROSS040]) }, 0)},([AR History].[AR Measures].[Recent Activity]])=0))}
But does count makes logical to have here ? Will it give the count of the returned values ?
Version: PAL 2.0.1
Excel Version: 2016 64-bit
Re: MDX Issue
Post by gtonkin » Wed Feb 14, 2018 6:38 pm
Try something like:
{Filter(
[AR History].([AR Measures].[Recent Activity],[Months].[Feb 2018])=0
The cube name should be after the tuple/set then the area defined within the brackets. I split the code for readability.
Re: MDX Issue
Post by tomok » Wed Feb 14, 2018 6:44 pm
Have you read the MDX Primer? You should keep a shortcut to it and refer often. Check your syntax for filtering on cube values and your mistake will pop out at you.
Analytics123
OLAP Product: Tm1
Version: 9.5
Re: MDX Issue
Post by Analytics123 » Wed Feb 14, 2018 8:04 pm
Can I have a Count surrounding the above expression .
