Hi guys,
I am facing doubt on trying to sum the amount of the same client in a cube as screenshot below.
In another cube, the customer will choose the "cliente" from a picklist, and I would like that after that the cube get the total value of this "cliente" selected, considering all rows that "cliente" is the same.
I tried to create another cubes to help me but it is not working.
Does anyone have an ideia of how to do this?
Thank in advance,
JR
Sum on TM1 Cube
- Version: 10.2
- Excel Version: 2013
Sum on TM1 Cube
- View of the cube
- Cube.jpg (294.13 KiB) Viewed 3726 times
- paulsimon
- Version: PA 2.0.5
Re: Sum on TM1 Cube
Make client a dimension instead of a measure and it is easy. At present you have the wrong structure
Re: Sum on TM1 Cube
Create a cube (as Paul suggested) with an extra dimension for "client" - this cube can contain all the same other dimensions as the cube in your screenshot and then is simply update by rules that say if the client measure in source cube for "Cliente" is equal to the client element in your dimension then populate "valor bruto" if not then 0.
This extra cube can be hidden and no one actually needs access to it; then in the cube you were going to create anyway; where they select client from a picklist - have that populate the value by looking up the hidden mapping cube.
- Version: 2.x
- Excel Version: 36x
Re: Sum on TM1 Cube
If you are on PA, store the client name as attribute and use the attribute as hierarchies. But again this will only work with PAx, Workspace but a more efficient and memory friendly way.
- Version: 10.2
Re: Sum on TM1 Cube
Thanks for the reply guys.
I will try this now and if I can't I send a new message.
Thanks a lot,
JR
Thanks a lot,
JR
- Version: 10.2
Re: Sum on TM1 Cube
Hi guys,
It worked. Thanks a lot for helping me.
See ya,
JR
See ya,
JR
