using the DependencyWalker (and working on a binding of the C-API based on the Java API Design minus the TM1V-ping pong), I found
TM1ViewCreateByExpression(TM1P, TM1V , TM1V)Code: Select all
TM1SubsetCreateByExpression(TM1P, TM1V, TM1V)I can easily create an example to create the expression based subsets. I haven't found any documentation how to create views by expression. Is this one just a stub? Any ideas how I could test it?
Markus
