Fresher..Rules & Feeders
Anuj4u2
OLAP Product: Cognos
Post by Anuj4u2 » Sat Aug 12, 2017 3:49 pm
Hi everyone i am new to TM1
what to do if source cube has more dimension than Target cube which doesn't have related to target dimensions
Source A Dim
B Dim
C Dim
Month
Year
Currency
Nos which has three elements NOS, ARR, Revenue.
Target Cube
A Dim
B Dim
C Dim
Alos
what should be rule for getting value of NOS elements from source cube to alos dimension of target cube.
tnx in advance
BariAbdul
OLAP Product: TM1,Cognos
Version: 9.5.2
Re: Fresher..Rules & Feeders
Post by BariAbdul » Sun Aug 13, 2017 1:16 am
Anuj4u2
Post by Anuj4u2 » Sun Aug 13, 2017 9:57 am
This might help:
http://www.tm1forum.com/viewtopic.php?t=4252 Thanks
Thank you for your suggestion,
I went through the post, it was somewhere same as mine but, not understood it properly.
my question is if I don't have month and year dimensions in target cube which is present in source cube.
then what should be the rule, if I hard code it then the value is not flowing correctly from source to target.
Version: PAL 2.0
Post by Wim Gielis » Sun Aug 13, 2017 10:30 am
Please show us your rule and also use real dimension names and cube names.
You should hardcode a value for the dimensions that you miss on the target side.
If your feeder is correct (assuming you feed this calculation) then it should all work.
Anuj4u2
Post by Anuj4u2 » Sun Aug 13, 2017 12:25 pm
Source Cube Service Profile
Dimensions
* Version
* Department
* SP_Pricing contain 200 elements
* SP_Sectors- 4 elements Service Profile which is consolidated elements, SP International, SP Institutional, SP Cash . this three are leaf elements
* Month
* Year
* M_Currency
* Measure Nos three element - Nos, ARR, Revenue
Target Cube;- ALOS
Dimensions
* Version
* Department
* ALOS - 1 element
so i want Nos value from Measure Nos Dimension and want to apply rule to consolidated
['Service Profile','ALOS']=C:(DB('Service Profile',!Version,!Department,!SP_Pricing,'SP Cash','??','??','Local Currency','Nos')*['SP Cash','ALOS'])+
(DB('Service Profile',!Version,!Department,!SP_Pricing,'SP International','??','??','Local Currency','Nos')*['SP International','ALOS'])
(DB('Service Profile',!Version,!Department,!SP_Pricing,'SP Institutional','??','??','Local Currency','Nos')*['SP Institutional','ALOS'])
what should be in place of '??'
Alos is independent of Month ie Constant but Calculated
Feeders;
[{'SP Cash','SP International,'SP Institutional'},'NOS']=>DB('ALOS',!Version,!Department,!SP_Pricing,'Service Profile','ALOS');
OR feeder can be written in ALOs cube itself .
[{'SP Cash','SP International,'SP Institutional'},'ALOS']=> ['Service Profile','ALOS'];
Version: PAL 2.0
Post by Wim Gielis » Sun Aug 13, 2017 12:41 pm
Valid elements like for example Total Year or All Years or whatever you call them, will be put instead of the ??
Anuj4u2
Post by Anuj4u2 » Mon Aug 14, 2017 3:45 am
Nope.
I tried, its pass a consolidated value..... Which incorrect.
BariAbdul
Version: 9.5.2
Post by BariAbdul » Mon Aug 14, 2017 6:03 am
Nope.
What Wim has advised you is the way to do in your case. You must have been doing something incorrectly...
OLAP Product: TM1, CX
Version: TM1 10.2.2 PA 2.0x
Excel Version: 2010 2013 365
Post by lotsaram » Mon Aug 14, 2017 6:20 am
Nope.
Not "nope". If you want help you post your code. And if you are serious about getting help you post your code AND you post a screenshot of subset editor the 2 missing dimensions showing what the top consolidation is called.
Right now you are time wasting. You are free of course to waste your own time but realize others may find it less endearing to have their time wasted.
Anuj4u2
Post by Anuj4u2 » Mon Aug 14, 2017 10:04 am
Nope.
Not "Nope". If you want help you post your code. And if you are serious about getting help you post your code AND you post a screenshot of subset editor the 2 missing dimensions showing what the top consolidation is called.
I extremely apologize for this, it was my mistake, I have to hard code the December month value, which was not mentioned in excel, I cleared it from Clint. Now my rule is working Properly.
Thank you for your Help
I appreciate it :)
