Array Variables
Christopher Kernahan
Excel Version: Office 2010
Array Variables
Post by Christopher Kernahan » Wed Mar 21, 2012 5:38 pm
I'm not sure if this has been covered before; I did search the Forum.
I used the below code to construct an "Array" in TM1. Each run of the While loop takes the variable and adds another value onto it, delimiting it with a ';' to identify the join. The second While loop deconstructs the array.
It was useful for my purposes but I haven't tested the performance or other (ie character?) limitations of this method.
iCount = 0;
iLimit = 10;
vArray = '';
WHILE( iCount < iLimit);
             vValue = Some Calculation or String Manipulation;
             vArray = vArray | vValue | ';'  ;
             iCount = iCount + 1;
END;
iCount = 0;
iLimit = 10;
              vValue = SUBST( vArray, 1, SCAN( ';', vArray) - 1);
              vArray = DELET( vArray, 1, SCAN( ';', vArray));
END;
Duncan P
Version: 9.5.2 10.1 10.2
Excel Version: 2003 2007
Re: Array Variables
Post by Duncan P » Thu Mar 22, 2012 1:03 pm
Have a look here
http://www.tm1forum.com/viewtopic.php?p=27954
The answer is that if you are doing this for small numbers of items (e.g. TI variables) it's fine. If you get into the thousands (e.g. items of a dimension) it is a very bad idea.
