Count dimensions in a cube via TIA
Posted: Tue Aug 19, 2008 4:34 pm
Thought i'd start a thread to share useful bits of code, here's one i've stumbled upon whilst writing some archival TIs this afternoon.
TM1, and TI in particular has quite a lot of inbuilt functions but occasionally they miss a few (ELISANC in Excel for one). Although TI has DIMSIZ to count the number of elements in a dimension, there is nothing to count the number of dims in a cube. When trying to recreate a cube via TI, thats a pain because you need to know how many dims to create it with to be able to write a "CubeCreate" statement.
Below is a short piece of code that works that out for you;
DimMax = 16;
DimLast = TabDim ( CubeName , DimMax );
While ( DimLast @= '' );
DimMax = DimMax - 1;
End;
- DimMax is set to 16 because i know we don't have any cubes bigger than that. If you do, then just set that higher.
- CubeName is a variable within the TI, in my case it's from a dimension subset that's the datasource for the TI.
