Cryptic TM1 Messages Decoded
iansdigby
Version: 9 + 10
Excel Version: 2007 Professional
Re: Cryptic TM1 Messages Decoded
Post by iansdigby » Tue Dec 04, 2012 10:37 am
On running any TI process that, inter alia, populates a cube:
TM1speak (in message log) : "Cell type is real"
Human speak: "You specified that a data variable was of type Numeric but the cube cell you are sending it to is a string cell".
(or vice versa?)
Excel Version: 2010 and 2016
Post by Alan Kirk » Tue Dec 04, 2012 8:15 pm
iansdigby wrote:On running any TI process that, inter alia, populates a cube:
(or vice versa?)
Real = Numeric. You'll sometimes come across an error like "cannot convert {whatever} to real" (can't recall the exact syntax of it); it means that whatever is trying to be input to a cell or otherwise manipulated cannot be converted to and/or is not numeric.
Edit: I expected that this would be referred to somewhere in the documentation, but the only place I can find it is in the API manual which is a place that most of those who don't wish to look programming death in the face and laugh at it will avoid. Page 10 of the 10.1 manual:
Value                  Description
TM1_REAL          A double precision IEEE floating point number.
TM1_STRING       A character string whose length does not exceed 64K bytes.
TM1_INDEX          A 32 bit unsigned integer.
TM1_BOOL          A logical value stored as 1 to indicate TRUE, 0 to indicate false.
TM1_OBJECT       A structure used to refer to objects managed by the API. Typically an object contains information about the server in which the object resides, and an index to locate the object within the server.
TM1_ERROR        A structure containing typically an error code and an error message string.
TM1_ARRAY        An array of values.
Items 1 and 2 are the only ones that apply to values stored in a cube, though.
Version: PAL 2.0
Post by Wim Gielis » Fri Aug 09, 2013 9:11 pm
Another one:
Data spread failed.
You are a read-only user - as set in the }ClientProperties control cube - and you try to edit a numeric cell.
GWT
Post by GWT » Thu Jul 24, 2014 9:48 am
"failed to create empty document" when double-clicking on a SUBNM in Excel.
Try deleting the .tbd files in %appdata%\Applix\TM1
