Recovering when an N element has been made a consol
paulsimon
Version: PA 2.0.5
Post by paulsimon » Thu Mar 01, 2018 5:16 pm
We had a situation today where some old code meant that our base level Balance Sheet Cost Centre had another element inserted under it making it a consolidation and we lost all our Balance Sheet data.
To recover I did the following
a) Amended the process to get the Balance Sheet element back to a base level element. I deleted it using DimensionElementDeleteDirect and re-inserted it using DimensionElementInsertDirect. I am not sure if the use of the Direct version of the functions was significant.
b) Unloaded all cubes using that dimension
c) Browsed them to bring them back in to memory
The result was that the data held against the Balance Sheet Cost Centre came back. This was despite the fact that the server had been shutdown and restarted twice since the dimension change was made. It would appear that the data is still in the .cub file and this approach gets its back. In the past other approaches had not recovered the data, and it was a lengthy process of going back to backups.
Version: PAL 2.0.3
Excel Version: 2016 64-bit
Re: Recovering when an N element has been made a consol
Post by gtonkin » Thu Mar 01, 2018 6:32 pm
Interesting that it worked-will hopefully commit to my memory, just in case I need a miracle one day. Thanks for sharing.
Excel Version: 2010 and 2016
Post by Alan Kirk » Thu Mar 01, 2018 7:04 pm
Very useful Paul, thanks. For ones like that you may want to post them straight into Useful Tips. (As an MVP you have access.) I'll shift this one over.
jim wood
Version: TM1 10.2.2
Location: 1639 Route 10, Suite 107, Parsippany, NJ, USA
Post by jim wood » Fri Mar 02, 2018 12:54 pm
Very useful indeed Paul, thanks.
Application Consulting Group (ACG) TM1 Consulting
OS: Windows 10 64-bit. TM1 Version: 10.2.2
Version: PAL 2.0.6
Excel Version: 2016 - Office 365
Post by Wim Gielis » Sat Mar 03, 2018 10:12 pm
Thanks Paul, will be handy.
http://www.wimgielis.com ==> 107 TM1 articles and a lot of custom code
Newest blog article: Turbo Integrator: report on progress
Elessar
Post by Elessar » Mon Mar 05, 2018 11:00 am
Hello and thanks,
I think "RulesOverwriteCellsOnLoad" can affect this: like deleting data by a rule. Is it turn ON on your server?
Sorry for my English ;)
