TM1 Tip - Parallel Processing with tm1runti
tiagoblauth79
OLAP Product: Cognos BI and TM1
Excel Version: 10
Post by tiagoblauth79 » Mon Oct 09, 2017 5:47 pm
Hi. I did create a code for parallel processing in TM1, based on tm1runti.exe. With this code, TM1 can run multiple processes at the same time. You can define how many processes you want to run in parallel and the code triggers as many tm1runti is requested. So, when one process is ready, tm1runti takes another process in the list to run, until all requested processes are ready.
Objects and instructions in the attached file. Enjoy :)
WINDM.zip
TM1 Objects and Readme
(304.46 KiB) Downloaded 81 times
jim wood
Version: TM1 10.2.2
Location: 1639 Route 10, Suite 107, Parsippany, NJ, USA
Re: TM1 Tip - Parallel Processing with tm1runti
Post by jim wood » Tue Oct 10, 2017 11:49 am
Moved this post to useful code, tips and tricks as it will be easily visible for longer.
Application Consulting Group (ACG) TM1 Consulting
OS: Windows 7 64-bit. TM1 Version: 10.1.1
