Delete method of Worksheet class failed
Posted: Mon Aug 28, 2017 1:04 pm
by gtonkin
Had a template that I needed to run TM1 Print Report on, but kept failing with "Print Report-Delete method of Worksheet class failed" - turned out to be a sheet that was flagged as Visible:=2-xlSheetVeryHidden.
Changed to visible and deleted in my case-all fine now.
Seemed fine if set to 0-xlSheetHidden but Print Report does not like xlSheetVeryHidden.
