Inspecting TM1 processes and chores
Posted: Sun Jun 18, 2017 3:09 pm
Here is a separate topic about how we can list properties of processes and chores.
The Main process can be used to execute the 2 subprocesses.
You can set up a cube (starting with }TECH_ so show the control objects when the processes have run),
or you can clean up the cube and its dimensions.
The output is large and varied, so have a go and see if it can help you when working with TM1.
The processes inspect the *.pro and *.cho files, respectively.
Original post: http://www.tm1forum.com/viewtopic.php?f ... 7a4#p65723
Below you will find the latest versions of the processes. TM1 10.2.2.4 is needed to run the processes as-is.
Any questions / remarks / errors / improvements: let me know.
Certainly the process to analyse chores is new, all input is welcome.
This work consists of almost 2,000 lines of coding, excluding comments and whitespace.
