RFE 93132 Better Handling of Multi-monitor and Undocking
Posted: Tue Aug 16, 2016 2:53 pm
https://www.ibm.com/developerworks/rfe/ ... R_ID=93132
If a Perspectives user is working on a laptop and has multiple monitors enabled, then puts the laptop into suspend or sleep mode, then disconnects from the secondary monitor (e.g. undocks), then resumes operation, it's possible for TM1 to try to display windows and dialogs on the monitor which is no longer connected. If the new window/dialog is non-modal, it appears that the system has not responded to the user command. If the dialog is modal, it's possible for the application to appear to freeze.
A workaround is to use the Windows Key + left/right arrow. However, Perspectives should poll workspace configuration and if a window/dialog is mapped to a non-viewable region it should remap it to a visible region to avoid this situation.
(As an aside, it's crazy that I have to submit this as an RFE and not a PMR-- this is textbook "defect" to me.)
