TI DeleteAllElements statement failing
Post bug reports and the status of reported bugs
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Post by Michel Zijlema » Mon Sep 19, 2011 2:35 pm
I just hit the following obscure issue (tested in 9.5.1 and 9.5.1 HF16):
When I have the following statements in my TI, the DimensionDeleteAllElements is failing:
DimensionSortOrder(v_dim, 'ByName', 'Ascending', 'ByHierarchy', 'Ascending');
DimensionDeleteAllElements(v_dim);
If I however reverse the order of the two statements, then the DimensionDeleteAllElements is working, so the following is indeed deleting all elements:
A thing to note about the specific situation is that all metadata changes in the regarding TI process take place on the Prolog tab (the process copies a hierarchy from one dimension to another by iterating through the source dimension using a WHILE loop).
I can't see any reason why the DimensionSortOrder can't be executed before the DimensionDeleteAllElements, that's why I would consider this to be a bug.
Michel
Gregor Koch
OLAP Product: Cognos TM1, CX
Version: 9.0 and up
Excel Version: 2007 and up
Re: TI DeleteAllElements statement failing
Post by Gregor Koch » Mon Sep 19, 2011 11:12 pm
Michel Zijlema wrote:I just hit the following obscure issue (tested in 9.5.1 and 9.5.1 HF16):
DimensionDeleteAllElements(v_dim_dst);
Michel
Is it maybe because you are trying to delete two different (unless v_dim_st and v_dim are the same) dimensions?
Michel Zijlema
Post by Michel Zijlema » Tue Sep 20, 2011 5:17 am
Michel
Hi Gregor,
Thanks for reading carefully :geek:
I've updated my original post - the difference in dimension name variables in the original post was caused by me editing the original code (which used v_dim_dst in all places) before posting.
Michel
Gregor Koch
Version: 9.0 and up
Post by Gregor Koch » Tue Sep 20, 2011 6:22 am
Well, I wasn't really of much help in that case and am not sure why this happens.
