TM1 doesnt release memory to garbage when element is deleted
Posted: Wed Aug 24, 2011 2:22 am
When you delete a leaf level element from a dimension and it there was some data in a cube for that element, TM1 does not release the memory allocated for the data against this element without retarting server or unloading the cube.
For example, if you have a dimension that you keep adding new elements every day loading data for those elements to your cubes and then deleting those elements after some time and adding new elements...ets, then TM1 cube memory keeps increasing over time and if you do not do a restart of the TM1 server, it will finally crash when it reaches the HW memory limits.
