Replication: Corrupt Dates in Logs
Steve Vincent
Version: 10.2.2 FP1
Post by Steve Vincent » Thu Aug 04, 2011 4:13 pm
Long story cut short; has anyone who runs replication found issues where some log entries on the destination server for attribute value changes have a corrupt replication date where the year is stated as 0000?
I'm taking a long time to narrow it down and get a reproducable model for IBM to test, but i can be sure that;
  • logs on the source server are 100% OK in every case
  • logs on the destination appear to be 50/50 split of OK or corrupt (no obvious pattern)
  • only changes made in bulk (ie via TI) & on large-ish dims (5000+) seem to be affected
  • no data is affected in this way, only attribute values
The problem it causes is if you have a chain of servers (A to B to C) where changes are made in A. They will replicate to B OK but the corrupt date in B's logs means the replication to C will miss those transactions.
Much longer explaination, hopefully with an example, to come later once i finish swearing at my PC and IBM....
Production: TM1 64 bit 10.2.2, Windows 2008/2012 Server. Excel 2010, IE11 for t'internet
Steve Vincent
Version: 10.2.2 FP1
Re: Replication: Corrupt Dates in Logs
Post by Steve Vincent » Thu Aug 04, 2011 4:20 pm
an example of said screwed up logs
"","20110804155624","00000804133635","Admin","S","83ZF02 -","Q75","}ElementAttributes_Work Breakdown","83ZF02","AltName",""
"","20110804155624","00000804133635","Admin","S","83B800 -","Q78","}ElementAttributes_Work Breakdown","83B800","AltName",""
"","20110804155624","20110804133647","Admin","S","83A011 -","Q153","}ElementAttributes_Work Breakdown","83A011","AltName",""
"","20110804155624","00000804133647","Admin","S","83A016 -","Q154","}ElementAttributes_Work Breakdown","83A016","AltName",""
"","20110804155624","00000804133647","Admin","S","83A017 -","Q155","}ElementAttributes_Work Breakdown","83A017","AltName",""
"","20110804155624","20110804133648","Admin","S","83A019 -","Q156","}ElementAttributes_Work Breakdown","83A019","AltName",""
"","20110804155624","00000804133648","Admin","S","83A020 -","Q157","}ElementAttributes_Work Breakdown","83A020","AltName",""
"","20110804155624","20110804133649","Admin","S","83A021 -","Q158","}ElementAttributes_Work Breakdown","83A021","AltName",""
"","20110804155624","00000804133649","Admin","S","83A022 -","Q159","}ElementAttributes_Work Breakdown","83A022","AltName",""
"","20110804155624","00000804133649","Admin","S","83A023 -","Q160","}ElementAttributes_Work Breakdown","83A023","AltName",""
"","20110804155624","20110804133650","Admin","S","83N001 -","Q161","}ElementAttributes_Work Breakdown","83N001","AltName",""
