STET Problem when element name starts with number
Post by tomok » Tue Nov 17, 2015 6:23 pm
I just ran across this issue today. I wanted to create a rule to apply to all the elements in a dimension, in this case Version, and then just STET it out at the top for the "Actual" version (we have multiple forecasts). So the STET rule initially looked like this:
[] = N:IF(ELISCOMP('TAX - NT - Version', !TAX - NT - Version, 'Frozen Versions') = 1, STET, CONTINUE);
I had one child under this parent called "2015 Q3 Forecast". The STET would not work. All the rules underneath continued to apply even though "2015 Q3 Forecast" was a child of "Frozen Versions". So, I decided to skip the ELISCOMP and do this:
['2015 Q3 Forecast'] = N:STET;
This didn't work either which is a no brainer that it should. So, I added another element as a child of "Frozen Versions" called "Q3 2015 Forecast", the key here being the element name does not start with a number. Voila!, it worked.
Has anyone else seen this before?
Version 10.2.2
Fix Pack 3
PS. This only happened on one server. Another server does not have a problem. Both are running the same version of TM1.
Version: 10.2.2., PAW
Re: STET Problem when element name starts with number
Post by Steve Rowe » Thu Nov 19, 2015 9:37 am
Since it doesn't _appear_ to be a version related bug, maybe the element is reserved or locked and that is confusing the situation?
Is the behaviour preserved through a restart?
