Cognos Planning 10.1 installation issue
Radhika
OLAP Product: IBM Cognos TM1
Version: v9.4.1
Excel Version: Microsoft Excel 2003
Post by Radhika » Thu Jul 05, 2012 4:15 am
Hello All,
I am installing IBM Cognos Planning v10.1 on Windows 7 with IIS 7 & Microsoft SQL Express 2005 SP4. Installation sequence is as folows
Database
Admin
Server
Client
Web configuration
Though I created a database successfully, I am facing problems during configuration. I created content store and planning store (localhost\instance name), while testing the planning store I get the below error message
[ ERROR ] Connection test to 'localhost\CSCINDAE680759' failed.
80004005: Unable to open connection using connection string of Provider=SQLNCLI;Data Source=localhost\CSCINDAE680759;UID=ASIAPAC\krandhi;PWD=********* and timeout of 15 seconds.
SQL Network Interfaces: Error Locating Server/Instance Specified [xFFFFFFFF].
[ ERROR ] Cognos Configuration is unable to access the Planning Store. Verify your database connection parameters, and then contact your database administrator for assistance.
Please help me.
Thank You,
Goutham
Anuradha
Re: Cognos Planning 10.1 installation issue
Post by Anuradha » Fri Jul 20, 2012 10:04 am
Have you used one database for Content store and planning store?
Is your planning store has been created with Bufferpool 32 and Tablespaces with it?
Anu
